R134a A/C conversion for 93 626
The A/C in my 93 626 just quit (compressor runs but air is not cooled). And it is the last year when R12 refrigerant is used. I saw some cheap conversion kits in the market and is wondering if it would work. This will save me big $ without having to tap into the dwindling supply of R12 refrigerant.
I have heard that the two refrigerant operates in different pressure and the old system may not hold the higher pressure. Also I heard that you need to change the compressor oil to convert to R134a but these conversion kits claims that you don't need to open the A/C system...
Any advice will be appreciated.
http://www.aircondition.com/
The most common problem with A/C is leaks, but if you have a leak, where is it? You have to FIX it FIRST!
Sometimes the compressor gets weak or blows seals or has internal mechanical failure, it has to be tested to be sure it works. Your new R134A refrigerant won't cool anything with weak or worn out components.
A retrofit will require the system be brought to very good condition, oil changed, new accumulator, new orifice tube or clean expansion valve, and other such things. It might not be as easy and cheap as you might think, to do it right.
Your best bet is to do like alcan said and go to
