Chrysler Town & Country 1996 Failed Transmission
I have a 1996 Chrysler Town and Country Minivan. I have 77,000 miles on it. We have a towing
package. We only tow a 16 ft. boat with it, maybe 6 times a year. Yesterday, my transmission
seemed to give out. Is there a history of transmission failures with this model/year?
The unit, particularly prior to 1998, seems to suffer from a number of premature failures. However, with millions of these units sold, to say the average mileage is 40-60 k before failure is gross exaggeration. It does seem to be a somewhat sensitive design.
Good luck, and once the proper repair is decided upon, if necessary, the proper transmission fluid is used. Nearly all repeat failures are a result of improper repair the first time.
http://www.allpar.com/fix/trans.html
http://www.thegrid.net/thedrivetrainpage/whtobuy.htm
I agree that failure shortly after replacement or rebuild is an issue with the quality of the rebuild - but the problems with this unit are not entirely due to the wrong fluid being used. You can maintain them by the book or better, using only Chrysler fluids and filter, and they'll still fail - and at rates higher than those of competing models from other automakers.
This unit has been problematic from the time it was released, and though it has been tweaked and improved somewhat, is still not designed to offer a 100,000+ mile lifespan, as many other competing models are.
Rumor says it will be dropped from the next generation of front-drive Chrysler Group cars, to be replaced by a Mitsubishi design.
