2000 VW Passat V6 Can't get key out of ignition
I own and have been driving my 2000 Passat V6 with TipTronic for almost two years now. The car has been problem free except for this recent problem with not being able to remove the key from the ignition. To date this has occurred 3 times total at different times.Twice in my garage and once on a road trip (bummer). Each time, I have gotten lucky and managed to remove the key.
Symptoms:
Problem occurs whether parking forward or backwards into a parking spot.
The driveway/parking space was flat
Car is shifted from Drive to Park or from Reverse to Park depending on whether you are backing up...you get the idea.
The Shifter is in the Park position
The display on the dash indicates you are in Park
You turn the key and you cannot remove the key from the ignition.
From what I have observed the last time, it looks like the release button on the shifter itself was partially engaged. On other occassions I did not notice if the shifter release button was partially engaged or not. I presume there is a sensor that detects that I am out of gear and this is why I cannot remove my key???
The steering wheel was not in a locked position so that was not the cause.
Of the three times this has happened, I have gotten lucky by doing the following.
1) Engine is off.
2) Foot on the Brake
3) Shift from Park to Neutral (sometimes even Drive) then back to Park
This last time I had to move it to Tip mode, shift back to Drive mode then up to Park.
Anyone out there experience this problem?
G.T.C.
Symptoms:
1) Engine is off.
G.T.C.
I plan on buying a 2001.5 or 2002 VW Passat GLX at the end of the year... I hope these problems are not common.
