Car starts very rough
When I start my car, the engine works very roughly for a few first minutes. It may even stop and need restarting. After a while the problem seems to dissappear and you can drive seemingly well. It also whistles a little bit as you drive.
Any idea what that might be?
Make: Chevrolet
Model: Corsica
Year: 1993
Thanks a lot.
Make: Chevrolet
Model: Corsica
Year: 1993
Thanks a lot.
Is it something easy to fix or should I go to the garage?
As for the a/c, I don't understand the question as you've written it.
Mr. Shiftright
2. Well, let me try to rephrase. The air conditioning switcher has sevral positions. Among those are 'Off', 'Maximum', 'Heat', 'Fan' etc. The problem with my car is that effectively only two positions work: 'Off' and 'Maximum'. Switching to any other position results in the air conditioning working as if it is set to 'Maximum'.
Another problem, which might be in fact related, is that when the airconditioning is off, some air still leaks inside.
That might be the problem?
Would removing an airbag fuse do the job? Frankly, the manual says, no and it recommends to undo the steering column and disconnect some connector. But I don't understand how a circuit can work without a fuse and if it can, what it's for.
