2012 Jeep Wrangler Long Term Road Test
Edmunds.comEdmunds.com Member, Administrator, Moderator Posts: 10,315
edited February 2015 in Jeep
image2012 Jeep Wrangler Long Term Road Test
Read daily updates on our long-term road test of the 2012 Jeep Wrangler and follow along as our editors live with this car for a year.
  • codydavenportcodydavenport Member Posts: 2
    Thanks for the tips, made for a smooth first oil change.
    I really like the Savegre wheels you have and the BFG 33s (285/70/r17 i assume?). Do you have any lift? If not, have you had any trouble with tires rubbing? I'm wanting to get this same setup. Thanks for the help!
    Thanks for the tips, made for a smooth first oil change. I really like the Savegre wheels you have and the BFG 33s (285/70/r17 i assume?). Do you have any lift? If not, have you had any trouble with tires rubbing? I'm wanting to get this same setup. Thanks for the help!
  • actualsizeactualsize Member Posts: 451
    Late reply: I didn't have a lift then, and they didn't rub significantly. Since then I've added a 3-inch lift for ground clearance reasons, documented elsewhere in this blog.
    Twitter: @Edmunds_Test
