Toyota Corolla Maintenance and Repair
After getting home with my new XRS I heard a strange ticking sound coming from under the hood. I checked and it sounded like a fast sucking/clicking from the top right corner. I buzzed back to the dealer and there tech had no idea what it was. When i got back home the noise was gone. Since then i have heard this noise a few times, but each time i take it to the dealer it isnt clicking. anyone out there have any ideas?
close at it comes.
I noticed my new 99 Corolla makes a ticking sound.
It happens when I shut off my engine after a
drive. That was when the weather was colder, and
now it has disappeared. It sounds just like "tick,
tick, tick..." continuing on a regular rhythum. I
don't know if it only happens during the break in,
or was it because of the cold temperature. I
check all my fluid levels very frequently, and
hasn't noticed any leaks.
Any of you new Corolla owners had this experience?
It disappears in about a minute. If it is engine cooling off, why the noise?
Thanks in advance.
I just noticed a little wind weezing noise + little vibrating sound coming from my driver side front door on my 99 Corolla LE. It only happens when I go over a bump or pothole. It sounds like air leaking into the car via the door seal, but there doesn't appears to be any water leaking in. I originally thought it was the antannae whipping about when I hit a bump, but even when I fully retracted it, the noise is still there. Has any one had a similar problem? It's not loud, pretty faint, but noticable w/ radio off. Some suggestions pleas.
Any ideas?
Oh, here is another stupid story. I thought I heard a vibrating noise coming from the driver side window. I was worried, turned off the radio and listened closely. Noticed it only happens when i drive over rough pavement or bumps. I was debating whether I should take it to the mechanic. The next day (before I went to the mechanic), while I was driving, I realized that noise was coming from my wrist watch's. I wear my watch pretty loose, and every time, I drive over a rough spot, my watch band(metalic) would shake like a wind-chime and produce that noise. God I felt really stupid.
If it includes the value package, then it probably is a good price. Best of luck.
Overall, do you think it's the best car you
could buy for the price? Thanks
So I think you can probably get a few hundreds bucks discount from there.
check out carsdirect.com and see what price they give you. i think corolla has $500 dealer incentive (at least it used to two months ago)
The $14,100 is the out of the door price (tax and tag included). With value package, it would probably be a good price (as long as sales tax is 3% or higher).
alohoa2:
I think its the best car when comes to daily commuting. Not the sporties handling of cars, but it's the most reliable economy car with possibly the best over all engine out there.
If you want to drive for fun, try a Mazda protege ES instead. It should cost as much as a TOyota CE w/ value package.
and it is bugging me a lot...
i spoke with a few dealerships... and they were not able to help me out... one suggested to trade in the vehicle and take a CE!
any help is appreciated...
thanks in advance
Gus,
Conference Host
I've just bought a new 99 Corolla CE, 4-speed automatic. Its engine whines when accelerating, especially between 10-40 mph. Is this normal with Corollas or should I have it serviced?
Raz
http://wellengaged.com/engaged/edmund.cgi?c=Smart_Shopper
gus
conference host
fan. I can't get it to shut off,I replaced the relays and the radiator fan switch with no luck?
Otherwise, you're looking at a complete rebuild on the engine if the belt goes. And that's around 4 to 5 grand.
You end up spending the money at 80K or 60K, either way, from Gus' advice.
Gus
Conference Host
I have noticed one problem.
When I start driving my car in the morning after starting and allowing 30 secs for engine to warm-up, I get some noise from the brakes when I apply the brakes.
Can anyone tell me why this is?
My sister contacted the "zone" manager and got the same story. I want to escallate the problem to the next level - does anyone have any advice? Who is the next level? How can I get Toyota USA to notice (rather than being ignored by the dealer)? Post here or at ctmurray@sowashco.com. TIA
You'll spend the money this year, or next year. Even if one is in a financial situation whereby it takes an extra month or two to pay for the maintenance - is THAT amount worth the relative risk.
It all depends on the person, I guess. A lot of people carry minimal disability, or home, or liability insurance. And, on average, they're OK without it. But, by definition, some portion of the people have their lives destroyed, financially. As I said, it depends on the person.
I just notice some noise when I was driving my 200 0 Corolla. When I start slowly, there is no such noise. But when I press the pedal harder, there is some noise, more like hissing noise coming under the hood. It is not smooth hissing noise, but it is also not knocking noise. But it is something other than engine whining.
Did anybody experience the same/similar thing?
Can some body tell me what kind of oils (I am sure there are some numbers) to buy for my Toyota Corolla 1994 model.
[Background:
For the first time I wanted to fill all the needed oils, and went to Pep-boys to buy. I must confess that I was puzzled to see arrays of different numbered oils. Unfortunately, I don't have my car manual to help in chosing the right oils for the following FIVE.]
1. Power steering fluid
2. Break fluid
3. Transmission fluid
4. -------------(One more, I donot know its name)
& 5. Engine oil
I am planning to buy Chilton Repair manual to help me with all the needed info. But before it could arrive, I shall need this information.
Hope some body would help me.
Srini
Many other Prizms and Corollas' engines whine, it's a widespread problem. Is there anyone who took his car to a Toyota dealership because of this? Did they tell you the same BS the Chevy dealers told me?
I think that the only way to have this problem fixed is to let Toyota know about the problem, maybe they can do something about it. Maybe if we all call/write Toyota and ask to talk to a manager there or someone in charge then we could figure out what's going on.
