-September 2024 Special Lease Deals-
Sienna Owners: Problems & Solutions
Has anyone else experienced "creaking" and and slight "rattling" from the sliding door on the drivers side? If so, is there a fix for it? The dealer claims not to hear it when we bring it in, but having just returned from a 1200 mile trip - I can attest to its existence!
Please advise on what may be causing it, how to fix it, or at least how to temporarily "deactivate" the alarm system.
Sure I can take it into the shop, but I am asking for help BEFORE I take it in so I do not have to pay an excessive labor charge to pinpoint the problem.
I am sincerely grateful for your help, thanks!
my sister's 97' camry have a similar problem. her locks would sometimes lock/unlock while the door is open. it would also make a loud "click" with the door closed - sounds like when you press your power door lock button. we're just waiting for the system to stop working and replace it with a new one!
if you're not good with wirings, it would be better to take the van to the dealer. it may still be covered by the warranty. i've seen this happen on my sister's car and also my nephew's car. both are caused by the alarm system.
goodluck.
I have been reading on this board that others have had the same problem with their transmissions or torque converters.
I am getting all my research inorder and then going to the dealership giving them the opportunity to fix the problem at no charge or reduced rate.
any advise would be greatly appreciated.
angie
lrsmom@hotmail.com
Previously, the first dealership stated and insinuated several times, I should have changed the tranmision fluid every $15,000 because Michigan is considered a harsh environment to drive in. I disagreed stating the manual doesn't indicate this.
Hope this is of help
mcf2
Jeff
you can ask your dealer to fix it free of charge if they will agree to it or replace the pads with aftermarket pads and hope the squeak will go away or just like me... remove the drums every few thousand kms. and clean it and learn to live with the squeak. yes, it's troublesome and annoying but i love the van. its so much better than the caravan that i owned before so i learn to live with the squeak. to me, the squeak is nothing at all compared to having to re-build my caravan engine twice with under 80,000kms. at over C$1000 each time! my sienna currently have 63,000kms on it and its 3yrs. old and the only problems i had with it are the squeaky brakes and alignment of front wheels which is now fixed.
just my $0.02
The Sienna has 29,000 miles and it is getting very annoying. If I hit a bump, the CD player will skip one or two songs easily.
Should I have the dealer repair it or replace the player? Anybody has similar problem? Thanks.
Howard
Larry
I checked the A/C switch, it is not pressed and I do not have the setting on defrost.
Is it my imagination? I'm going to the dealer and start a used 2002, if they have one on the lot, and compare.
Otherwise, we love the ride and quality to date.
Lastly, has anyone heard anything from Toyota regarding the swinging sun visors. Any remedy ??
Visor remedy: duck! ;-)
Larry R
it sounds like a vacuum that just suck something up.
Does anyone has the same feeling?
to cut down on the body leaning on to one side is to slow down when you turn. my sienna leans also when i take a fast turn so i just slow down when turning.
You are certain of your tire pressures, of course. Be sure to follow those listed in your driver-side door-frame.
BTW, I'd like a video of the van leaning right when you turn right ...!
Also, you cannot compare a van with it's significantly higher center of gravity to a Prelude. Totally different spectrum of the motoring wold.
FWIW, I've been driving my wife's sport sedan for about a month now - she's almost 8 months pregnant and can't climb out of her car anymore, so I offered her the Sienna for the duration. Anyway, I needed the van one day last week - thought I was going to roll it in that first hard right! So while they ARE on totally different ends of the motoring spectrum, some of us would benefit from remembering the comparison. LOL
BTW, jasdmw - I've always wondered if moving from S to H or V (or 65 to 60 series) would help with the roll. I didn't figure it would help much, thought most of the "softness" could be traced to the suspension rather than the sidewall stiffness. Glad to hear someone had a positive experience in that regard - it may very well make a difference when I finally wear out these darned Firestones. (Why is it that the lousiest tires seem to last the longest?)
Larry R
Larry R
Seb
Rob
Next problem, two of the buttons for the preset radio channels have come off and I don't see how to put them back in place so that they will stay. Help!!
re: buttons - short of pulling off mine to see what's underneath, I can't really help you there!
Larry R
2002 Sienna XLE
I need to get a new battery anyway to make sure my wife and daughter don't get stranded.
Anyway, I looked at the receipt today, and it says "Remanufactured Transmission". I don't like this - although the Sienna seems to be working OK now. Is is common to put in a rebuilt tranny instead of new? I'm going to call them tomorrow.
Dave
I solved it by topping off the brake fluid.
I have since purchased a 2002 Tacoma (new) but no such mirror was available via Toyota. (Reason perhaps: Driver's side fold down sun shield doesn't clear the wider Gentex type mirror.
I purchased a Gentex SD mirror with builtin compass and temp. from J.C. Whitney who periodically has coupons for free shipping and/or discount. You can read all about the Gentex mirrors at <http://www.mitocorp.com/nvsmirro.htm>
I installed the mirror on our Tacoma and had no difficulties in doing so. You do have to free up the left/driver's side windshield pillar trim and headliner (only along the joint meeting windshield) to get wire run up to new mirror. Comes with pretty decent instructions and there is toll free # at Gentex for help.
You can do it!
Ed M.
could be the button itself is a bad one.
could be anything.
If you find out something simple - post it, I'd be interested too.
This also goes for other parts that are reman'd by Toyota. Starters, alternators, and the like.
Important thing to remember is that it is not used or only the parts that have failed are replaced, it is all new.........
By reusing the case on the transmission Toyota keeps the cost down a bit. All reman trannies are bench tested to assure they are up to snuff.
For thos of you at or around 60,000 miles with this problem it should be covered under the powertrain warranty. I noticed one person at 69,000 you may want to take the partial payment. If the 5/60 warranty is up Toyota does not need to offer you anything.
I do not work for Toyota Motor Sales but for a Toyota dealer. Just wanted to share this info to make sure that you, the consumer are aware that Toyota internals are nothing to worry about on these trannies.
FYI......I have never seen a reman tranny go bad on ANY Toyota, so the quality is just as high as the original.
Trying to calm some fears
make sure they check your 2000 sienna and make sure it wasn't one of the 2000 model year that had a manufacturing problem with the transmission.
I remember several posts over a year ago discussing a bad production run in June/July?? 2000 with bad transmissions. It's the only other posts I've seen here over the years I've been monitoring Edmunds.
cliffy? You were around back then, does this sound right?
The dealer says they spoke to their rep right???
Request a meeting with Toyota's Parts and/or Service Manager or DPSM as Toyota calls it. Tell them you want to talk with them personally.
The dealer should accomodate you without a problem.
when you talk to the DPSM point out that though you are over on 60,000 mile part of warranty you still have 5 years!!!! Tell them what is on your mind. The DPSM reviews things like this on a case-by-case basis.
Let them know you are frustrated, and worried what will be next...... Oil GEL problem...
What region of the country are you in???
I can call and find a name for you.
Let me know.
Toyota's "GoodWill Policy" is pretty lenient. The consumer usually is unaware how to play the game
By the way, did you buy an extended warranty??? OR buy it used as a Toyota Certified Used Car
