Crank sensor check engine light. Toyota Sienna.
I just changed my timing belt and water pump. Car runs great but ck engine light came on for the crank sensor. Any ideas?
Answers
Did you dislodge any wiring working on the engine?
I don't know if you disturbed the ECM harness at all, but the P016 can also indicate an ECM signal problem.
