Engine over revs and blinkers don't work (sometimes). Help! Olds Alero.
true24true24 Member Posts: 3
edited October 2014 in Oldsmobile
I took my 4 cyl 2004 Alero to the GM dealer because the turn signals work less and less frequently and to top it off, the battery light comes on and the engine revs up to 4000rpm going a max of 40 mph! When the battery shuts off a minute later, the engine runs normally again. This only happens when the car is cold (after I get off work), but the lights do their own thing when they want. No blinker, no sound. The dealer wants to charge me $1000 for a new alternator and control module, but I just changed the alternator, battery, fuel pump, and had a tune-up. Can anyone help?
Best Answer
Answers
    No matter if you just changed it--if the battery light is still on, you have a charging problem, and if the alternator or battery isn't functioning well enough to provide proper voltages to the car's electrical system (hopefully somewhere around 13.8 to 14. 2 V), then your car's modules are going to go nuts.
    So back to square one here, and have someone at least put a voltmeter on the battery terminals while you rev the engine, and see what it reads.
    Thanks for the response. I had the alternator and battery tested before I took the car to the dealer. They both passed.
    So the dealer tells me that I need a new alternator and a new BCM. I think he is trying to play me about that last thing. From what I have read, it looks like the BCM controls things like the radio, trunk, and passlock security, and I don't have those problems. However, I do have an engine light on that I can't get rid of. Any idea how to reset it?
