Repair head gasket or get rid of 98 stratus?
I've got a 98 stratus w/ 58,000 miles on it. Bought it used. Just found out it has a blown head gasket. It has not been overheating yet... Repair could be anywhere from $200 - $800. The dealer will trade me out of the car. Do I get rid of now - while I can or do I get it repaired??
Thanks for you input
Once you have this number, go to the Edmunds Home Page and look up the True Market Value of the Focus you are buying.
This should give you a clear idea then of what kind of deal you are getting and whether bailing out of the Stratus is going to hurt you or not.
If it isn't really costing you anything to bail, and if the Focus is affordable to you, well, then, maybe it's the way to go. But if you are actually overpaying on the Focus just to get out of the Stratus, you might as well use your money to fix it rather than just hand it over to the dealer as extra profit for him.
The owner's manual says it should hold 4.6 qts with filter change.
Should I go by the dipstick or add the extra .6 qt which would show over full on stick? I suppose the stick could be wrong.
Do you like it?
If the car is relatively trouble free, and you like it, then the right answer is to put a new head gasket in it.
The head gaskets have been improved, so make sure your mechanic puts a good one on there.
Of course have the other maintenance stuff done while there. If there is a timing belt, have it replaced, any hoses that can easily be replaced while the work is done.
Might as well pay for the labor only once.
TB
