Low oil pressure light and bell
jeff43614jeff43614 Member Posts: 2
edited November 2014 in Chevrolet
Will be driving and all of a sudden the low oil pressure light comes on. We've had the oil changed twice since it started from two differnt places so it's probably not a dirty oil filter. Happens more when we turn a corner. What could this be?
    If it's happening when you turn a corner, that certainly indicates that the oil level might be low. Read the dipstick with a cold engine next time. If the oil is being changed at a quickie lube type place heaven only knows what they put in there. Having the correct weight oil for your engine is very important as is the use of quality oil filters.
