Correct Tire Pressures - 2015 Volkswagen Golf GTI Long-Term Road Test
Edmunds.com
We might have found one reason our 2015 Volkswagen GTI is below its projected fuel economy.
So to recap...Edmunds has complained about the lack of traction under acceleration and the fuel economy, which are both symptoms of underinflated tires, then they after doing that, they check the tires and find they're underinflated.
Maybe you could check to see if all these items are set to spec, when you take delivery, before you start publishing assessments of the car's performance - ? And really, to begin to criticize the car's fuel economy when it has under 1,400 miles on it...
1. Exactly what pressure will cause the TPMS to alarm?
2. I don't do track driving, so my primary concern is treadwear. 33 could wear out the edges; 37 could wear out the center.
3. Since the car isn't running at full load (presumably), is 35 perhaps a better setting?
Does anyone else see the humour in this? They have a $250 gauge but hardly ever check their fleet vehicles' pressures.
A friend with a Mk VI GTI runs his car at 40 psi for fuel econ and handling/ride reasons. Even the slightest drop in pressure seems to have an immediate effect on economy on my 3 or my buddy's GTI.
