warped brake rotors covered by warranty?
I own a 1998 Grand Cherokee Tsi and have experienced the warped rotors caused by the fact the factory built these vehicles with rotors made of composite materials. I have read postings and believe some of you may have had this problem covered under a warranty program of one sort or another.
For myself, upon having the rotors and brake pads replaced (at 55,000 miles) I was informed by the dealership that 1)not only are the rotors not covered by any warranty, 2) they are not available in "all steel".
Any input from members regarding the warranty coverage or an upgrade for this item is appreciated.
I every other case, rotor warpage is usually covered only until 12,000 miles.
Rotors are technically a wear item, sometimes there is an initial warranty on some wear items, as previously Chrysler was replacing rotors on the LH cars under warranty for a number of years, as they were first introduced. But given the age of your jeep, it's not likely it would be covered anyway.
Take your Jeep to a brake shop, because they should be able to locate rotors for your jeep, specifically, cast iron rotors.
Otherwise, go to a decent shop and get the rotors turned or replaced. If this is the first complaint of brake rotor warpage you've had and you're at 55,000 miles, considering today's non-heat absorbing brake pad material, it's a true miracle - count your blessings.
I'm pretty sure that's the only one currently open for a 98 model. I could be wrong though, so you may want to run a recall search at www.nhtsa.dot.gov to be sure. DC has issued several TSB's over the years for the rotor problem. Maybe you still have some recourse here also. Again run a search on NHTSA.
The current rotor TSB that replaces both the rotors and calipers cover 99 through 02's built prior to 5-02. So this one wouldn't help you.
With the age/mileage on your's, you may be out of luck. If so, simply replace the rotors with any decent set of aftermarket rotors. That will take care of the problem once and for all... and at half the cost your dealer will charge you for another crappy set of MOPAR rotors.
I would say count your blessings, you've done better than many people.
So what are you gonna do. Most manufacturers will not even cover rotors during the initial warranty period. ....At least it is not a terribly expensive fix. Most of the time the rotors can be machined. But even if they are toast, they are relatively inexpensive compared to other repairs.
so I haven't been too cranky over it, it's another safety tax. can't do anything about it, whether you riot or not, so what the hay.
