Is there only one key entry on the drivers side to the Pontiac Torrent?
i have the wire harness problem in the drivers door as we speak. i just got my window up but now the door lock doesn't work and my remote doesn't work. how do i get in this vehicle
Best Answer
thecardoc3
Member Posts: 5,871
The drivers door has the only lock cylinder that can be used with a key. If that is also not functioning, you will need a technician to assist you in opening the door. Now might be a good time to join AAA.
You "could" attempt to open the rear glass or hatch, but due to communication issues with the drivers door module shut down that may not work either.5
Answers
