Do I really need a diesel truck?
I am a truck person and will soon have to buy another one. This is my second Toyota and I have at least 300,000 miles (odometer broke several years ago) but need a crew cab with two children that are growing up. Why do I think I want a big truck? Well, I take several long trips each year plus my job adds 75 miles per day round trip (90% interstate). I am a very big man but not over weight and have been uncomfortable riding in the two Toyotas I have had in my life. I do not need to haul or pull really anything at this point, however, the wife and I are going to buy a pop-up camper next year. I can go out and buy a GMC crew cab or Ford 150 crew for less than a F-250 diesel, but the gas mileage stinks. From what I have read diesel might be a great alternative because of the interstate miles that I will rack up on the truck. I have talked to several people that have the F-250 diesel trucks and they love them. They get around 19 miles per gallon on the interstate. What about these new diesel engines coming out in January with even better fuel economy and less pollution/noise? I would really appreciate any advice you can give me.
Keep in mind that oil changes are 15 qts, and filters are a bit more expensive too. Also need to keep up anti-cavitation additive in coolant to prevent cylinder wall damage. If you live in cold climate, you'll need to make sure you're using winter mix fuel so it doesn't gel on you. Plus the engine block heater helps make starting quicker on those cold winter mornings. Lot of folks also carry around an extra fuel filter in case they get a load of water in their diesel fuel. However, if you buy diesel at same place big-rigs do, it's fresh and properly blended for the time of year, and water doesn't get a chance to condense in their storage tanks.
Personally, diesel exhaust is not exactly perfume to me, and motor is too loud. My friend garages his truck, so there's always a fine coating of soot on everything in there. Don't get fuel on your clothes, or track it into truck - it smells pungent and stains are difficult to get out of carpet. Of course it won't blow up like gas :-) But if you're in love with diesels, then those are trivial points.
I know what you mean about needing a crew cab for kids, Superduty CC is immense inside. My kids used to fight over who had to sit in back of my old F150 SC. I'm 6'5 - 270lbs and am thoroughly comfortable - have split bench seat. Now everyone is happy. Of course my CC,V10 usually only gets 12-13 on highway.
Guess it all boils down to your personal choices. Just a thought - go for long test drive with one. Try parking lots, tight turns, drive thrus, etc. get a feel for the bulk and the maneuverability. They're pretty responsive for big pickup, but it's a big step up from the Toyota.
A diesel truck will represent a significant cost delta over a gas truck, both in initial cost and maintenance. This increase in cost will be easier to justify if you have the need to haul extremely heavy loads and/or put a lot of miles on a vehicle. There are other disadvantages that wpalkowski has listed, including anti-algicides for the fuel and somewhat limited diesel availability (compared to gas). A mechanical problem with a diesel engine could also represent a significant cost committment.
If you need four doors and still want a truck, there are other alternatives that are in the 18-21 MPG range and cheaper to maintain. Both the Dodge Dakota Quad and the new Explorer 4-door truck might be something for you to look at. These are not as roomy as full size pick-up quad cabs. However, if you're like most people the rear seating will be used a small percentage of time anyway.
Good luck,
Dusty
since you don't haul you can live with the small v8 (4.6)
You can dress this truck up anyway you want. It's a great
family vehicle.
Initial cost and individual maintenance items are more expensive. But, the Superduty CC is considerably larger than the SuperCrew. Also, the first 100k or so miles will pay for the extra cost of the PSD, then it starts paying for itself in fuel mileage. You said that you drive 80 miles one way to work, chances are you pass at least one truck stop on the way, so diesel availability should'nt be a problem.
Before the 2500 I had a 1500 with the 4.8L engine. With the same camper and driving style, it averaged 15.0 mpg. That truck was slightly over the GVWR at 6440# loaded. Without the camper, it got 16-17 in town and 22-24 on road trips.
While I would really like the low end torque of a diesel, I've never been able to justify the upfront cost and maintainence. I would probably be happy with an F250 PSD, but I'm also happy with the 2500 6.0L and the extra cash in my pocket.
Mike L
I have had F150 and now my second F250. The only thing I miss is the smoother ride. The F250 is for WORK. The suspension is suited for it quite nicely. My truck rides nice with about 800 or more pounds in the bed.
If you are interested, you could probably find an off-lease F150 just the way you want it.
http://www.thecarconnection.com/index.asp?article=5476&sid=181&n=157
I have taken it to the dealer and they wanted to use the "shot in the dark" method of fixing the problem (to me that meant they had no idea of what it was). However, they wanted to replace my ball joints. I asked them not to hold off ... as I wanted to get a second opinion, as it did not sound right to me.
Does anyone have any suggestions?
To find out more, go to
http://forums.thedieselstop.com/ubbthreads/,
Do a search on front end noise or spring tip isolators - there's a lot of info on it. Some people have lubed the spring leaves, while others have gone to upgraded heavier "X-springs" in order to seek noise relief.
I've got '01, 350, CC, 4x4 w/V10 - on cold mornings the front end is squeaky. Especially this morning with 6 degrees on the thermometer. Squeaks last for about the first 5-10 minutes and then disappear. (Actually, when it's this cold everything squeaks, including me.) Buddy of mine with '99, 350 PSD is going nuts with the squeaking - his front end is heavier than mine. Not sure, he may already have x-springs as I think he's got heavy duty suspension option. He's had spring isolators put on and sprays some silicon lube on them when noise makes him nuts, unfortunately the quiet only lasts 'til the first rainstorm. Actually I don't notice squeaks that much when I ride with him - volume of PSD drowns them out. ;-)
Again thanks for the info .... I have made an appointment with my dealer to take my truck in and will share any info I receive.
I have also seen it come from a sway bar. If you pull the swaybar and lube the inside of the rubber where the metal rubs with a synth lithium type grease is unsually that fix.
Good Luck,
Robert
I can tell when it kicks in on a take off but how do I know when the turbo isn't being used?
Cooldown times: Well, this is where we really need a pyrometer. I admit, I have a $35k truck, at least when new anyway, and I haven't spent the $175 to get a pyrometer. But, I don't have a chip or any other performance pieces either. This is what appears to me to be the general concensus about turbo cooldown. Normal around town driving, empty, the turbo will most likely be cooled down from the slow drive down your street. Provided you live on a side street. Most days, I come off the highway and onto my street. From the time I slow down at the stoplight on the highway, wait for the light, drive 1/2 mile to my street, drive 35 mph down my street, approximately two minutes, then take another minute to pull into the drive and into the garage, I figure mine has cooled down enough. When you are running high speeds and/or towing, you'll need that five to ten minutes to cool down. Anytime I am towing, it takes me about that much time to park the trailer and unhook before pulling into the garage.
If your really worried about it, or if you have any performance mods, you should get a pyrometer. Just as soon as I can sneak one past my wife I'll have one.
on edit: That time that I use to let the turbo cool down, I use that time to unhook my seat belt, set the parking brake and get everything else in order.
I've had a basic understanding of turbos so it makes sense it's always going.
Paul
