Tacoma Front Disc Brake Squeal
tacomaguytacomaguy Member Posts: 41
edited January 2015 in Toyota
I own an '05 Prerunner with 56k miles. Had the front pads replaced and turned the rotors last Spring.
Now, after sitting for awhile, as I back up the front brakes squeal.
(Sounds like a rock in a caliper its so loud.)
Toyota has a TSB to fix this.
    You aren't putting many miles on the Prerunner - surprised they don't grind like mad when you drive it going forward until the rust wears off.
    What's the fix?
  • tacomaguytacomaguy Member Posts: 41
    Turns out there is a TSB for this fix. Dealer won't bring it up unless you complain about the noise when backing.
    I am out of warranty but I had the dealer fix the problem anyway and now no noise.
