2014 Acura RDX- transmission vibration on shift
rmontyrmonty Member Posts: 1
edited January 2015 in Acura
I have a 2014 acura awd rdx with 27k miles. i've noticed recently that during the shift intervals there is 4-5 sec vibration as the transmission shifts through gear 3 to 6. it doesn't seem to occur when manually shifting using the S-mode and the steering wheel mounted paddles. i search these forums, but didn't see anything similar so i put this out. checked the tranny fluid and it looks fine. under warranty so i'll be taking it into the acura dealer soon.
  • Could be something other than the transmission, possibly. Are you under harder acceleration when you notice this? Possibly some sort of engine vibration you're feeling as it shifts? I assume it didn't do this earlier on. You don't notice it shifting with the paddles, so it's possible what you're feeling is something that may be "normal" or related to something other than the transmission itself. But the dealer ought to be able to give you more insight into that. Let us know how it turns out!
