Break-In Road Trip- 2015 Ford Mustang GT Long-Term Road Test
Edmunds.com
This is the text a search engine will offer the reader as description of your page in the search results. Be sure to include 2015 Ford Mustang GT and aim for around 150 characters.
Sounds like an ideal trip for a self driving car.
Your Mustang is essentially brand-new, so it has the factory tires. All recommended PSI values are determined with the assumption that you're running the same tires as what came stock. On most cars, a different/replacement/non-OEM set of tires, even of the same size, can allow for a few PSI of adjustment to fine-tune the ride or handling. Even with stock tires, you can normally raise or lower the pressure by 2-3 PSI to smooth out the ride a little or stiffen up the sidewalls for better handling. I normally run mine on the low side whenever I know I'll be doing a lot of highway driving so that the ride is a little less busy.
