Oil Change #3 Due - 2014 Toyota Highlander Limited Long-Term Road Test
Our long-term 2014 Toyota Highlander is due for its third oil change.
From Toyota Owners FAQ:
Only Toyota vehicles in which 0w-20 synthetic oil is required (except for the 2TR-FE and 3UR-FBE Engines*) have been approved for extended oil change intervals of 10,000-miles/12-months. (However, you should continue to check the oil level regularly and top off if needed. That will help your engine get the full benefit of synthetic oil.)
i went back and checked on their 5000 mile maintenance and they say nothing about an oil change or cost or anything:
http://www.edmunds.com/toyota/highlander/2014/long-term-road-test/2014-toyota-highlander-5000-mile-service.html
only the 10k mile service mentions an oil change:
http://www.edmunds.com/toyota/highlander/2014/long-term-road-test/2014-toyota-highlander-10000-mile-service.html
and as another owner confirmed in the first post the oil only gets changed every 10k miles.
kind of annoying that they suggest that you bring in the car so they can, basically, look at it. sorry, if it were mine it would go in every 10k miles only.
The maintenance minder system in Hondas is the best. I don't like looking up the codes but the system not only tells you when oil changes are needed but it keeps track of filters, transmission fluid, engine coolant, timing belt/water pump, spark plugs, and SH-AWD differential fluid. It will also try to combine service with oil changes. If the transmission fluid needs changing every 50,000 miles, for example, but the oil needs changing at 45,000 miles it will request the tranny fluid change early to keep you from making an extra trip just for the transmission. Oil life is calculated not just by miles but temperature, driving conditions, number of cold start cycles etc to decide when to change the oil. The rest of the services are mileage based only.
