Are you a current or recent car shopper who bought an EV and then installed solar – or who had solar already, making the decision to go electric easier?
OR
Are you a recent EV buyer (past 3 months) as a result of manufacturer incentives and dealer discounts on these vehicles, including year-end deals? Were you convinced to buy an EV after finding a good end-of-year deal, or due to uncertainty around which EVs will no longer qualify for full/partial EV tax credits in 2024? A national business reporter is interested in speaking with you. Please reach out to [email protected] by 12/15 if interested in sharing your story.
GMC Sierra Will not idle
gwhuntergwhunter Member Posts: 2
edited February 2015 in GMC
gwhuntergwhunter Posts: 1
February 16 edited February 16 in GMC
This truck starts will run as long as you float the throttle but when you stop it stalls emmediately. Here is what has been changed. The egr valve, map sensor, computer, fuel pump, iac, spark plugs, wires, distributor cap and rotor, had control module checked at parts store, ok, checked fuel pump relay with meter, bench tested oil pressure switch because of it's backup circuit to fuel pump, egr solenoid, back probed all sensors and relays for proper voltages, ok, checked tps ok, plenty of spark and good compression on all cylinders. If I put external vacuum on map sensor and hold my finger on the vacuum port I disconnected it from it will run. I'm not grasping what this is telling me. Any help at this point would be appreciated. It only throws a code 43 which is knock sensor. I haven't checked that yet but would that make it not run at idle. I can't keep it running long enough to try and drive it. Forgot to mention it is a 5.7 L.
Flag Quote · Like LOL
