Updated Transmission Software - 2014 Jeep Cherokee Limited Long-Term Road Test
Edmunds.com
After hearing complaints from owners about its transmission shift quality, Jeep has offered up a software upgrade. We're not sure yet if we're going to take advantage of it.
The Cherokee has received a couple of software updates since launch, so it's possible that Edmunds' example received one of the later ones on the manufacturing line, hence no major issues observed. I read an article about the 9-speed unit, and it is pretty amazing tech, but the occasional odd-feeling shift is inevitable due to the design.
"These bulletins differ from recalls in that they are not considered safety or emissions issues and they usually apply only when your vehicle is in its warranty period (whereas a recall is "open" until the work has been performed). TSBs frequently (but not always) address a recurring problem and include illustrated instructions for repair, a list of the parts needed, the warranty status and the labor charge."
So out of warranty, out of luck (depending on your dealer, the manufacturer, whether it's really is a "silent" recall and what the cat had for breakfast).
How Can a Technical Service Bulletin Help Me?
Have to wonder if "updating software" is one of the check-offs the prep-tech is supposed to do when a new car arrives at a dealer or before it's delivered to the customer.
I don't know if it's true (or maybe I don't quite understand the engineering) but supposedly the upcoming Ford designed 10-speed auto for trucks will really be a 8 speed with different 4th and 5th gear ratios available depending on tow/haul mode is engagement.
Depending on the Chrysler dealership, they may use a technology called Wi-Advisor which is a wifi based system in the service lane. They hook a Wifi dongle up to the OBD-II port in the vehicle, relaying all vehicle info into a tablet which will show the service advisor if anything is necessary for the car (TSB, stored code, etc.). It also saves time for the advisor to pull up customer info and vehicle info. Very great technology making its way into an increasing number of dealers.
Also, when a car gets its pre-delivery inspection it should be checked for any necessary software updates (which I believe is the real question here, but I misread it initially and wrote all the stuff above which is still kind of relevant).
