2015 Chevy Equinox gas tank and mpg
Hello, I just purchased a 2015 AWD Equinox. I am perplexed as to the gas mileage, tank size, etc. My 08 equinox seems better on gas mileage. Does anyone else have this issue? I had about 1/8 of a tank left, no fuel light, and yet it only took about 13 gallons. Makes no sense. Thanks!!!
May as well check two or three tanks manually and make sure the dash mpg is accurate - usually they are, but not always.
Your target is 23 combined with the AWD. You can play with your mix of city/highway driving here and dial your target mpg in better.
Your tank holds 18.8 gallons. It's likely going to be pretty rare that you'd put more than 16 and a half gallons in it, unless your low fuel light isn't very conservative.
Which engine do you have , the 4 or 6 cyl ?
