Loss of Steering in turns 2002 Silverado LT 1500 Z71+
Summary - 2002 LT Silverado 1500 v8 Z71 shortbox extended cab plus towing and much more, no cap/weight in rear, less than 8k miles. Loss of steering was last night in a right hand turn at 30-35 mph. Felt like front tires were coming off and the steering wheel bucked like crazy, car was coming the other way and the truck already was making a point of not wanting to make the turn and stay on right side of lane (going 10mph less than limit because of symptoms), had to straighten out the wheel and bail into a driveway just in front of the oncoming car. Please relay TBS#s, assembly terminology and references, that I can communicate to help me get the Dealer to listen.
Additional Info - At 500 miles I informed dealer of thunk/thump/klunck in steering wheel in turns (with or w/o brakes didn't matter). At 6k miles she gets worse, but this time braking after the shakes starts will make for a real interesting ride (braking on straight has no symptoms). Straight aways are okay (except this morning), all the chevy trucks I've ever had weave-when-windy, but then again, all the chevy trucks up until this one could handle a simple turn (heck, a bronco II or one of those suzuki-rollover-suv's could have handled this turn better). This morning the dang thing started darting left and right on a straight away (worse then when windy). I'm driving my 1989 Silverado twinn until someone can help me find TBS info, part/assemblies to investigate, terminology, and/or other ammo to go back to dealer with. Suppose Chevy couldn't just reproduce the 5.7L 1989 1500 - best truck I've ever had in 30 years (best chevy was my 1967 ChvII Nova SS). Oh, symptoms seem to be like the 89 got at 180k miles which upper/lower ball joints/idlr arm fixed. Other facts, yes tires are GM mfgr stock (firestone AT's I think), pressure good, balanced, etc. and no I have not hit a pothole, curb, nor has it been off road yet, etc. Dealer says it is the nature of a truck - I need concrete reference numbers to go back to the dealer with (TBS, postings, something to get them to listen). And yes, after last night I'll probably spend the $120 to go to an unauthorized shop to get it checked. Could it be as simple as making the camber/castor/and toe-in closer then GM specs. Oh, as well as steering wheel clunking, you can feel the clunking under your foot when on either the gas or brake. Until resolved - I'm putting off replacing the tires with BFG AT's (Best all purpose tires and gets 60-80k+ miles if maintained, neighbors love the ride up the mountain-hill in the winter, and the tires are good for pulling the neighbors out of ditches). Oh, right turns buck/chuck/clunk more then left hand turns. Purchased Oct 2001 to help boost/support USA economy after Sept.11 (for real, no kidding): hopefully GM will help represent USA and fix the problem (lots of similiar postings on Silverado's since 97+ - so GM needs to stop sitting on it based on death/injury suits being cheaper then putting out a recall).
It sounds to me as if your idler arm broke or came loose from the frame. The truck cannot be safely driven if that is the case.
Harry
Ray T.
Scott
http://www.truckautoaccessories.com/acb/Directory.cfm?st=0&st2=0&st3=0&DID=9
Then you have complete control of your headlights.
I've used their 4 headlight system on 3 trucks with great success.
Oh, you could just put on the parking brake, and the headlights won't come on until you release the brake.
Mike L
