'88 Towncar seems to be leaking...water(?)
in Lincoln
My TC seems to have water dripped from a location close to the right front wheel after driving...it doesn't have engine overheating but I do have to add water into the tank every 3 weeks or so...is it normal?
The thing does not have a tachometer but I feel the engine is pretty stressed (loud) right before the tranmission engages a higher gear...is it normal?
and, I think the switch is just invonvenient because there are only 2 direction--open the sunroof on one end and close the sunroof while tilt it up to ventilate on the other end...how am I supposed to know when it is fully closed??
The first and second gear is fine but the engine revs higher and higher and at 38 - 40 mph...the engines runs and the car does not...I think it is the third and fourth gear's problem...does everyone agree with me?
How much will a new transmission and the labour cost to install it cost?
