Door hinge pins / door dropping.
sparky97sparky97 Member Posts: 1
edited March 2015 in GMC
My doors seem to of droped a little bit so it is hard to close the doors, so i bought replacement parts and replaced the door hinge pins but did nothing for my problem, does anybody know what to do about this.
    edited March 2015
    OK, if it wasn't the hinge pins, it has to be something. Could be a worn bushing that the pin sits in. Here's a video I found dealing with this issue on a GMC Jimmy. Although you may have replaced the bushings (you didn't say). I suppose it's possible the bushing wore out to the point where the hole the bushing sits in also wore down a bit.
    Other options that come to mind seem unlikely and way bigger issues. Bent door frame opening, door bent where the hinge attaches (see what I mean by unlikely and bigger?)
    Can you adjust the striker?
