Nissan Pathfinder Odd Oil Leak
I have a 1993 Nissan Pathfinder with an oil leak. The oil leak has gotten pretty bad, and I was convinced that it was either a cam or crank seal that needed replacing, since it was coming from the front of the the engine. I removed the belts and front cover, exposing the timing belt. Unfortunately, its dry as a whistle in there--so obviously it wasn't the front seal as I first thought. The oil leak is coming from a very strange place. Its dripping near where the water pump meets the block. Its not the oil cooler seal or an issue with the oil pan either--the leak is coming from higher than that. Any ideas what it could be? Any help would be GREATLY appreciated!
