schedule maintenance mdx 2011 base
zoom08zoom08 Member Posts: 75
edited April 2015 in Acura
I am looking for info regarding the flushing schedule for the cooling system (radiator)
My dealer is recommending that it is time to flush the rear differential fluid ($180+tax)
I was reading general info on the web but nothing really states when it should be done, other than when the dashboard shows the B6 code, menaing you need to change it right away.
any help would be appreciated
    You should replace the engine coolant at Maintenance Minder #5 and the differential fluid at Maintenance Minder #6
