Lincoln LS TPS problems
amyjo252amyjo252 Posts: 1
edited April 2015 in Lincoln
I have changed the tps twice and it keeps throwing the same code I was wondering if any one has had the same problem And what they did to fix it. There's a clicking noise going on right before the catalytics and a Miss. It's not throwing codes for a miss either. Also replaced the crank shaft positioning sensor.  :'(
