Hybrid battery doesn't charge as well anymore
jagj25jagj25 Member Posts: 1
edited June 2015 in Nissan
I have been noticing lately that my battery does not charge as well after being in traffic after a while. It charges when I brake but does not charge as much as it should, instead of showing a large charge it will only charge a certain amount and nothing more no matter how much charge is already in the battery. Has anyone else experienced this? Is it a sign of the battery going bad? It works perfectly the next day which makes me believe it has something to do with the heat
  • thecardoc3thecardoc3 Member Posts: 5,856
    edited June 2015
    The batteries are temperature sensitive. The cooler you keep it, the better it works. The battery temperature can be monitored via scan data with a full function scan tool.
