Calling Los Angeles-based car shoppers: Have you recently traded in (or plan to trade in) a car with negative equity (i.e. the amount you owe on your auto loan is greater than the car's value)? A reporter would like to speak with you; please reach out to PR@Edmunds.com by 11/6 for details.
2005 Ford Taurus. What does it mean when it makes a clicking noise and won't turn over.
tap11tap11 Member Posts: 2
edited June 2015 in Ford
my ford taurs 2005 want start makes clicking noise
Answers
    edited June 2015
    ONE click or rapid clicks? If rapid clicks check and clean your battery terminal connections and check your ground cable on BOTH ends. If that doesn't help, have your battery load-tested. If it's more than 5 years old, it's probably very tired. Once the car is running, you can check alternator output with a simple voltmeter.
    If you're getting only clicking, = the battery. Whether it is the connection or the battery itself is determined by your next steps.
    Also, the reason the battery is dead might be because the alternator isn't working.
