We are aware of the login problems affecting the forums, and appreciate your patience as we work on a fix.
Did you recently purchase a new Tesla, Rivian or Lucid vehicle directly from the manufacturer and willing to share how your experience compared to previous vehicle purchases made through a traditional dealer? A reporter would like to speak with you; please reach out to PR@Edmunds.com by 2/19 for details.
2013 Jeep Wrangler Unlimited Heating Problems
rugbyprop1rugbyprop1 Member Posts: 4
edited July 2015 in Jeep
My defrost and heat are blowing cold air. I turn the heat dial all the way to hottest setting but still blows cold. The A/C is turned off. I checked the fuse for the heating system it works fine. The blowers are blowing fine. Just blowing cold.
Answers
  • rugbyprop1rugbyprop1 Member Posts: 4
    This is for a 2013 Jeep Wrangler Unlimited
    First off I'd check to make absolutely sure your coolant level is at the correct level.
    After that, I'd feel the upper and lower (entrance and exit) heater hoses at the firewall in the engine bay, to see if the coolant is hot going in AND out of the heater core. If only one of the hoses is hot (after running the engine for a while, of course) then you must have a blockage or a defective heater valve or module controlling the heater valve. If both hoses are hot, then there must be a stuck actuator for a blend door or diverter under the dashboard.
    Thank you very much I will make those checks.
  • spuddyspudspuddyspud Member Posts: 1
    Having the same problem. 2012 Rubicon. Did you find the fix?
