Gas mileage and fuel capacity
I've had my XB 5-speed for nearly a year and 10000 miles. It as been dead on reliable and fun to drive. My gas mileage has varied from 26 to 31 in mixed driving and from 32 to 35 on the highway. I use premium fuel only because I can get it without ethanol. My fuel mileage also increased a couple of mpg due to getting the power robbing ethanol out. True it is probably not enough to offset the extra expense but I like not having the stuff in my car. My only dissatisfactions has been with the transmission gear ratios. They are way to low. This torquy engine could easily do with a ratio that would drop about 500 rpm for more relaxed highway cruising. As it is, though, my XB will go up any hill or long grade without breathing hard! Another is the instrumentation. I don't mind the center mounted set-up but speedometer and trip meter for mpg ratings are both inaccurate. My speedo reads about 2.5 mph high and the fuel mileage read out has about the same error, also on the high side. I have the stock 16" tires. The clutch has a narrow engagement band and can be difficult to be smooth on. The car is fairly quiet, is comfortable and this years hot, humid summer has shown it has one of the best air conditioners I have ever experienced in a car. I thought it might be an electric unit rather than a belt driven compressor because there is absolutely no perceived drag when the compressor kicks on.
5
