Where is the Acuator Door for 2013 Jeep Wrangler Unlimited
Does anyone have pictures of the Heat Actuator Door for a 2013 Jeep Wrangler Unlimited?
The blend door actuator is contained within a black molded plastic housing with an integral wire connector receptacle (2). An output shaft (3) with splines connect it to the blend door linkage and integral mounting tabs (4) allow the actuator to be secured to the HVAC housing. The blend door actuator does not require mechanical indexing to the blend-air door, as it is electronically calibrated by the A/C-heater control.
The A/C-heater control must be recalibrated each time an actuator motor is replaced
The blend door actuator is interchangeable with the actuator for the mode-air doors and the recirculation-air door.
