Odd electrical issue
I replaced a stock radio with another factory radio with an aux jack. I took out the old radio and waited until the new one arrived after discovering that replacing with an aftermarket radio was not going to work. So after I cut the wire harness out and realized that this swap was a no go, I re-connected the harness. During this interim everything worked fine and the car ran well. When I got the new radio thing got weird. everything was good until the day I got the new radio. even before I installed it which was quite easy, the power windows stopped working and although the blower fan worked the A/C stopped working blowing out just air. Drove it home with now windows or now power locks but still with the blower motor and no A/C. Went back out after a while and now the only thing working was the turn signals and the exterior lights. everything else is now dead so no cluster lights and now starter engagement. Took a break and went back out and then the turn signals stopped working. I doubt any of this is relater to the radio harness (the wire gauge is so small and likely carries very low amp) so what could possibly be the problem? All the fuses checked out and everything was working fine until the day before yesterday. Things started to go out even before I installed the new radio...Ghosts? I am charging the battery right now but I have doubts about that since the interior dome lights do not come on. Any ideas???
