-September 2024 Special Lease Deals-
Honda America cannot solve 2016 Honda Pilot setting issue.
autodriver
Member Posts: 9
I purchased a 2016 honda pilot EX two weeks ago. I need to bring my car to honda service department in one week.
Because I canoot personalize the door setting, this feature keep go back to the factory setting. Also, if you are honda owner, when you lock the car you will see a light flashing on your dashboard or radio, but my car it only flashing one or two hours then it turned off. Sometime it turn off at once if I press the lock button again.
The honda service said they need to contact honda america tech support.
The Honda America tech support reply is they cannot solve the problem in this moment, But when?????????????
How??????????????????????
They should study this vehicle before release it
* If this is a safety issue* OMG
The locking light indicator is a red flashing light that is on once you lock the car. With my new pilot, it disappear after a while. It is not normal.
I am concern that Honda America tech will reply that they can not solve these two problems at this moment because the car is too new? So when is the correct moment. If the manufacturer doesn't have all the answers, who else can solve then? If these were safety issues and you get a response like this, what would you think? My life and the life of my family are at risk if the car is not safe, right?
I have been an owner of a 2016 Pilot for about a month now, the car has a problem with it's command unit for sure. I noticed it the nextday after pick up of the car as I tried to set my preferred method of locking and unlocking of the doors as our previous 2014 Odyssey had been set up. Along with that I noticed the sound coming out was not the same as my Odyssey, well it's shy about 50 watts which still does not justify the loss of bass in it. Took it to the dealer to have it check along with the same front end noise as the Odyssey had and they told me there was no fix for it, yet this time there is no bulletin for a fix on the Pilot. Good luck to all trying to get some of these issues fixed for now since the car is too new and probably not enough complaints to Honda.
