What's the fix for erratic security light?
allhallows2allhallows2 Member Posts: 1
edited August 2015 in Buick
The security light in my 1999 Buick Regal has become erratic and sometimes the ignition key won't start the car. The manual says to wait three minutes, but I'd like to know if there's a way to stop the problem from occurring.
Answers
  • imidazol97imidazol97 Member Posts: 27,810
    edited August 2015
    Do you have the resistor chip in the key? Clean the resistor contacts on the key.
    Dip it in rubbing alcohol and insert quickly into the ignition to clean the two
    contacts there that touch the resistance contacts on the key.
    Most likely you need to bypass the contacts in the ignition lock by
    doing a VATS bypass where the wires from those two contacts go
    to a resistor set that you solder together from Radio Shack type
    places to match the resistance of your key's chip measured with
    an ohmmeter.
    There are videos on you tube.
    Another way might be to have a shop that installs car alarms
    bypass the key lock for you, since they do that to install their
    own security device. They have the resistors already made
    up for the GM VATS and are familiar with the location of
    the wires under the dash. Once it's bypassed, you no longer
    have the resistance check as a security--just the keying
    of the key to slow down someone wanting to take your car.
