Are you a current or recent car shopper who bought an EV and then installed solar – or who had solar already, making the decision to go electric easier?
OR
Are you a recent EV buyer (past 3 months) as a result of manufacturer incentives and dealer discounts on these vehicles, including year-end deals? Were you convinced to buy an EV after finding a good end-of-year deal, or due to uncertainty around which EVs will no longer qualify for full/partial EV tax credits in 2024? A national business reporter is interested in speaking with you. Please reach out to [email protected] by 12/15 if interested in sharing your story.
OR
Old Car, Modern Tire Tech - 2007 Dodge Charger SRT8 Long-Term Road Test
All four tires were suddenly low but luckily this 2007 Dodge Charger was ahead of its time.
As a follow up question, changing tire size also could change the camber and castor, could it not? Is there a way to calculate the proper toe-in, etc?
the manufacturer suggests its settings based on even more than what you listed. comfort, mpg, tire wear, etc...
what first got me thinking about it was the various pressure settings bmw listed for our vehicle depending on the number of occupants, what type of driving, etc...
i realized that different pressures work better for different circumstances. this is something race teams have known since the beginning of racing. tire pressures are constantly adjusted for track conditions. some times if you go off-roading you might want to "air down".
i don't think changing tire/wheel diameter or width affects most alignment settings. if it does it would be so small that (unless you are already on the ragged edge of manufacturer specs) it really wouldn't matter.
and you can go outside manufacturer specs if you know what you are doing; you just better do your homework first.
this guys says it can (he doesn't mention diameter):
"...fitting a car with a wheel or tire combo that has a different offset or width will affect camber, toe, and caster angles in the suspension. ...
Even where the alignment is corrected, there can be significant changes in the scrub radius of the vehicle and unfortunately, in almost all production cars, scrub radius cannot be directly adjusted."
http://www.tuneruniversity.com/blog/2011/04/wheel-tech-part-ii-size-matters/
i think the important take from his articles (and something i've done) is to stay as close to the manufacturer specs/tolerances as possible and you don't have to worry. i've used a wheel that is well known in the mustang community and my alignment was adjusted after lowering and is within manufacturer spec (though at the very edge of negative camber).
