Do I need to take timing belt off to change water pump on 01 Concorde?
rachelrobrachelrob Member Posts: 2
edited September 2015 in Chrysler
trying to change water pump
Answers
  • thecardoc3thecardoc3 Member Posts: 5,871
    What engine? The 3.2l? yes the timing belt has to come off because it drives the water pump. If its the 2.7l then it is the timing chain that must be removed and there is a newer design double chain that goes back on, which means it gets a new set of cam and crank gears, chain guides, tensioner and oil pump.
