95 Jeep Grand Cherokee 4.0 2wd
I was having tranny issues. I pulled the tranny and the shaft is chewed. I know I have to replace the torque convertor and the drive plate. What would cause this shatf to get all chewed up? Should I look further into the engine?
Answers
1.) If your transmission locks at a relatively high speed stopping the input shaft from turning with the torque converter, this can destroy both the splines on the input shaft and the splines inside the converter.
2.) If the torque converter fails and locks up, it can destroy both the splines on the input shaft and the splines inside the converter.
3) If someone recently changed the transmission, and the input shaft splines were not lined up correctly with the splines inside the housing, or the transmission pump engagement wasn't aligned correctly upon installation.
