Button in trunk does not work to partially raise and lower the folded roof.
The yellow button in my trunk does not raise or lower the folded roof a bit, as it used to do. The main roof operates properly when completely raising and lowering from inside the car. I've checked all fuses. Any help or suggestions would be appreciated.
I also have another unrelated problem. Ever since buying this car second-hand, there has been a pesky one drop of oil per night under the engine. It's in the area of the oil filter housing, but it's not that. There is also an oil-sender switch is in that area which I suspected, so I replaced it. But I still have that aggravating one drop every day. I've spent a lot of time looking for this leak. Anyone else ever had this problem?
