-September 2024 Special Lease Deals-
Engine cuts off, no power while underway
bertmbcbertmbc Member Posts: 9
edited September 2015 in Dodge
Sprinter 2006, 2500, ~196,000 miles
While underway, the engine suddenly with no warning, stops. It will restart immediately afterward
There is an DTC code P0201 Injector circuit/ open cylinder 1.
Earlier the same happened except the code was P201 injector circuit open cylinder 1 cylinder 3. I drove it to the dealer 50 miles with perhaps one restart in that distance
The dealer replaced the injectors on both cylinders 1 and 3.
A very few thousand miles and two weeks later the same occurred...... the engine ceased on the hiway. it could be restarted and run perhaps a half mile. The dealer replaced the ECM and reprogramed it
Today the same happened with the P0201 code as before. the engine restarted while coasting and made it about a mile home
The electrical circuits have been checked for shorts. The injectors 1 & 3 have been replaced. The ECM has been replaced. The Sprinter has been driven ~ 2,000 miles with no problems and then the engine stopped. The technician recounts all the stuff I can read on the internet as being checked as a cause
Apparently something on the injector circuit is sensed and the ECM turns everything off. It is scary
Is there a suggestion as the cause to the problem?
