Starting Problems
I have had problems with my 2002 Altima starting on 2 different occasions. The first was in January and the second time was this morning. In both cases, the last time I drove it was for about 30 seconds, moving it from one side of the driveway to the other then leaving it for at least a day. Then when I'm ready to drive it, the car won't start. After the Jan episode the dealer said that I should just pump the gas. That was also the case today. In each case, it still took a while to start. Anybody else have these issues?
I am not convinced that we should be pumping the gas. What's the point of having automatic fuel injection (rhetorical)? I am taking it to the dealer tomorrow morning to have it checked.
I think there is a fix, some kind of a cam sensor needs replacing, not an expert here
check out this forum
http://www.nissantalk.com/forum/forumdisplay.php?s=&daysprune- =&forumid=51
you can do a search on "won't start" etc, many others with the same problem
