Towing w/ 2500
I currently have a 6000 lb travel trailer and am looking for a new tow vehicle. Am considering Dodge Ram 2500 Quad Cab short bed w/ Hemi. I want to get a truck that will allow me to tow a 5th wheel in future. I know any 2500 will handle my current trailer, but what about the 5'er.
Here is some more info:
unloaded 5'er weight is 7500 lbs
GTW of 5'er is 9900 lbs
pin weight is 1450 lbs
Considering the HO Turbo Diesel is not available in Massachusetts, it is either the SO TD or the Hemi. Test drove the SO TD and hated the lack of power from the get go. Thought the hemi would be fun to drive.
Here are my questions:
Can I tow a 5'er with the short bed?
The Hemi 4.10 axle ratio tows 10800 lbs. Am I pushing it?
Any gas mileage results for Hemi w/ 4.10?
Thanks in advance for the help.
We need to know three things. What is the actual wet weight of the truck, not the dry weight of the base model truck. What are the GVWR and GCWR for this truck? Once we know those numbers, then we can decide if this 5'er is within the manufacturer ratings.
Dodge Ram 2500 Quad (Hemi 4.10):
GVWR - 8,800
Curb weight - 6,073
Curb weight F/R - 3,380/2,693
Payload - 2,730
GAWR F/R - 5,200/6,150
GCWR - 17,000
Max trailer weight - 10,800
5'er:
Dry weight - 7218
Carrying capacity - 2701
hitch weight - 1460
So, it looks like I am w/in spec for all weights. Correct?
But, is the short bed enough to tow a 5'er?
For the sake of arguement, I'll assume the curb weight is for the truck you are looking at, with all options installed. The curb weight, I believe, is its dry weight before any fluids are added. In order to run a "real world" calculation" we'll need to add for all fluids, passengers, gear, hitch, coolers full of your favorite beverage, etc.... Let's assume two adults, 150 lbs each, and two children, 75 lbs each - there's 450 lbs allready. A full load of fuel, oil, battery, etc... can easily go 250 lbs. If you have a crossbox, like myself, full of all the necessities, jack, tools, chains, extra oil, extra coolant, etc... lets use 200 lbs for the box and everything in it. We need to add for the 5th wheel hitch and all its attaching hardware - approximately 200 lbs. Well stop there, but I'll bet you'll also have some firewood in the truck bed, at least 150 lbs. But we won't count that.
So, before any firewood, the total weight of the truck should be approximately 7,173 lbs. That leaves you only 1,627 lbs of pin weight capacity. Now, you've listed a pin weight of 1,460 lbs, which is almost exactly 20% of the dry weight of the 5'er. If you are very careful how the 5'er is loaded, then you can squeek by with only 16% on the pin. However, I'd bet your pin weight will most likely go into the 1,900 lb range. You will probably go over the manufacturers stated limits on this truck.
Now, will that truck pull it? I know it would if it were the Cummins and I'd bet that Hemi will do just fine, maybe struggle a little in the mountains. I see 3/4 tons pulling larger 5'ers than that all the time. Would I do it? Probably not. Especially since you haven't bought the truck yet. Look at a similar 1 ton. Or does Dodge even offer a SRW 1 ton? I know Ford does, but Chevy doesn't. The Ford is rated at 9,900 lbs and would handle that 5'er just fine. If Dodge offers a SRW 1 ton, I go that route. The price probably isn't much more and the extra safety margin will make your towing more relaxed and enjoyable.
Can you tow a 5'er with a shortbed? Sure you can. However, there are a few things to keep in mind. First off, get a slider for the hitch. With one of these devices, you can literally slide the hitch back to gain camper to cab clearance when tight parking manuevers are needed. The hitch slides up and locks in the towing position for all other times. The main thing to watch out for are those times when the truck and 5'er are approaching a 90 degree angle. The problem with the shortbed truck is not that it can't pull the 5'er, but that the "cab to camper" distance is less than the "center of the hitch pin to the side of the camper" distance". Measure the distance from the center of the pin to the edge of the camper. Then measure the distance from the back of the truck cab to the centerline of the rear axle. If the truck measurement is less than the camper measurement, then the two will contact each other when making tight turns where the truck and camper relationship exceeds roughly 60 degrees. The slider effectively increases the distance from the cab to the axle centerline, making the near 90 degree manuevers possible. An extended pin box may help some, but it will not offer the same benefits of the slider.
I am looking to buy a bigger truck to replace my '99 GMC Sierra 1500. I need a truck large enough to pull a 38' travel trailer with a dry weight of about 8,700lbs., a GVW of about 11,300lbs and a hitch weight of about 1,200lbs.. Since I never plan to pull it with the tanks full, I'd estimate the maximum weight that I would be pulling would be about 9,700lbs, including passengers.
I love my GMC, but the new GM's and Ford's seem to be priced much higher than the Dodge Ram trucks. I've only owned one Chrysler product in my life, and that was a lemon. I really like the looks of the Ram 2500, but I'm gun-shy. Are these newer Dodge trucks reliable? Can I pull this trailer with a 3/4 ton 2500, or am I going to need a 3500 instead? I'm looking for 4WD with a crew cab and a gas-powered engine. Any thoughts?
Did the exact same trip last March with the Ford. The engine just did not have the power to pull. Constant shifting up and down, 7mpg, and the always present feel of "are we gonna make it..."
Yes, the 2500 should handle your load fine with the Hemi but if you intend to do any serious towing, I'd strongly recommend the diesel.
Now, for my experience. I have a '99 F-350 Powerstroke with the 6-speed. While I don't have to worry about tranny temps as much as guys with automatics, I do change my fluid every 30k miles. I have a Western Diesel Turbo Brake. This exhaust brake is a real brake saver on long downhills. I can really feel the brake engage when engine rpm's are over 2k.
Dusty
