Keep in mind that during Fall season cars get clogged with leaves and plant debris, so check under your hood for leaves and clean out everything around your window vents. If that doesn't fix the problem, try cycling through the knobs to see if a setting got stuck. Listen for a fan noise when you put it to defrost, if you hear the fan but the window is not defrosting, then you most likely have blockage somewhere.
