-September 2024 Special Lease Deals-
99 Jimmy starting problem.
so my daughters jimmy wont start.... was running fine... then had to repair main positive wire to battery...all ok... then intermittently started not cranking....turn the key and it just clicked... used jumpers on solenoid to jump manually it would click a coule times and then would start.... thought starter was gone so replaced it.... fired right up... shut it off and wouldnt start again....mostly just clicks and sometimes it will go wuh wuh wuh... thenback to clicking... tried a different battery and hooking up cables to boost it ... had good amp at batt 12-13... starter turned nicely when tested out of vehicle .. any suggestions ?
Answers
