hvac drain hose
curler108curler108 Member Posts: 1
edited October 2015 in Pontiac
I can t find this do I look from top with hood open or only from underneath the car ?
    edited October 2015
    Depends on the car but often you can see if when you open the hood and look behind the engine, in about the middle of the firewall. Sometimes you'll need a lift to see it as on some cars it's down low behind the engine. I'm pretty sure on your car you'll have to jack it up and peel back a heat shield to gain access to the drain hose.
    There's a service bulletin about this if you want to do more research:
    #09-01-37-002D: Water Leak into Front/Rear Passenger Floor and/or Carpet Wet (Inspect White Plug in HVAC Evap Drain and Apply Sealer to Front of Dash) - (Sep 27, 2010)
    Subject: Water Leak into Front and Rear Passenger Floor and/or Carpet Wet (Inspect White Plug in HVAC Evaporator Drain and Apply Sealer to Front of Dash Area)
    Models: 2008-2010 Chevrolet Cobalt
    2008-2011 Chevrolet HHR, Malibu
    2008-2010 Pontiac G5
    2008-2009 Pontiac G6
    2008-2009 Saturn AURA
