Will crank, no start, no codes.
toolmanxiiitoolmanxiii Member Posts: 2
edited November 2015 in Dodge
2004 sx 2.0 . died on the road . would crank but not start. so far I've replaced the timing belt. crank sensor cam sensor ASD relay. still nothing . I have had no codes at all other than check engine light flash 9 times if I cycle the key 3 times and wait 15 seconds after the done .shows
  • neonexpresso99neonexpresso99 Member Posts: 1
    I had a similar problem Turned out to be , oil pressure was low , my check engine light did not come on
