stalling on deceleration or when coming to a stop
                    can someone please help me! I have a 99 bonnie
with 97k. here's a bit of history since i've own this car. the firth month the can run great! when about once a week the car would stall sitting at a red light and i notice that it got harder to start.(about 1-2 sec. holding the key in the start postion). took it to the shop, they had it all day and said it would cost about 800 dollars and that was only for a tune-up and a coil pack. i was like WOW you are kinding, rite?!? so i stoped at the parts store on the way home and bought plugs, wires, gas and air filters, about 80 bucks.
after removeing the fuel filter i notice a rust color goo in it! thats it i said to me self a dirty fuel filter! the car started rite up! not the 1-2 sec start, and ran great again for a week or two. i replaced the fuel filter again, it had a little less goo this time. once again the car ran better (not great)this time. now it doesn't matter if it's a new filter or not it keeps stalling.
i have checked all the vac.lines using carb spray and found no leaks. also cleaned the EGR, pvc and the IACV(idle air control valve). once again this seemed to do the trick! but again the stalling returned!
now the car stalls at least 10 times on the way to work and 10 times on the way home.
but now the check engine lightcomes on when the car stalls, the code is P0172 and that sulphur smell coming out of the exhaust. at a light the RPM gauge will start at 800 and steady and then jump up to 1500 down to 500 back up to 1000 then to zero and stall. some times the car's computer will try to fix this proplem(i think) and over do it causeing the car to jump forward slamming the trans into gear hard like.
this stalling thing is VERY dangerious for me and i'am a guy just think if a woman or elderly person were driveing it when it stalls and have no power steering!
please help me track down this hugh problem.
gary
gary
1. disconnect this plug(Takes all of 5 seconds!)- you'll end up getting about 3/5 mpg less per tankful or
2. take it to a Dealership to replace the unit- it ran me around $300 to $400.00 to get it fixed the first time- it did it again a few years later and i just had my mechanic disconnect the lock up plug -no more problem.
Good Luck,
Chuck
The actual unit that I had replaced is called THE TRANSMISSION CONTROL MODULE.
It allows the TCM to shift the Trans and turn the LOCKUP on or off.
The plug i'm referring to is connected to this unit. Disconnecting this plug should correct your problem.
the first thing I did was pull the vacuum lead off the fuel pressure regulator, guess what, fuel was dripping from it and when I left the car running and vacuum line off gas was spitting from the FPR!! so off I go to the parts store and I will post my results when finished! thanks alcan!
the TCM Y will keep that in mind if the FPR doesn't do the trick. but i'am thinking thats not my problem this time. i had a buick years ago that had that kind of problem but it only stalled when in gear.... my car will stall in park or in neutral. thanks for your input, I have seen wierder things!
not the TCM.- My Mistake.
think that did the trick!!!
5 mechanic overlooked and had no idea what the problem was, one of them was from the dealership! why is this, are mechanic not trained today the way they were years ago???
i'am just glad i found someone that is a MASTER of their trade!!!
i will post again in a week just some others that may read this know that the fuel pressure regulator can and will cause this kind of stalling problem on GM cars.
easesame please read the later post by alcan
sorry that i can't help you,any more then that.
