Calibrating the Rearview Cam - 2007 Dodge Charger SRT8 Long-Term Road Test
edited October 2015 in Dodge
imageCalibrating the Rearview Cam - 2007 Dodge Charger SRT8 Long-Term Road Test
After installing a backup camera in our 2007 Dodge Charger SRT8, we found that the path lines on the touchscreen weren't calibrated properly. We set out to correct it.
  • notfastnotfast Member Posts: 93
    Video "may appear reversed"? Yikes!
  • s197gts197gt Member Posts: 486
    how does an aftermarket head unit know you are in reverse?
  • dgcamerodgcamero Member Posts: 148
    Probably taps into the power line from the reverse lights? I can't really think of how it'd (as simply as possible) work otherwise.
  • csubowtiecsubowtie Member Posts: 143
    I'm guessing it taps into the ECU, which would also let it know things like speed, for use in Navigation, or for automatic volume adjustments.
    youtube install video talks about finding your reverse light wire... so at some point you need to hack into that i guess.
