Dodge Dakota Starting problems
Hello all. I have a 2002 3.9 v6 Dakota that recently started having starting problems after the truck sits for a while. Especially over night. I go to start it in the morning it turns over fine tried to start but will sputter and die. After about 10 mins of doing so it will sputter for a min then die. Eventually it starts but just barely running then it will clear out and idle like normal. If I shut it off and start it it starts right up like normal. And will run fine all day. Only happens after sitting a while. I have replaced plugs wires, coil pack, battery, and fuel pump and problem still exists. Any ideas?
Answers
Two, you have a leaking injector that drips gas into the cylinder and fouls the spark plug until such time as repeated starts clears the plug of extra gas.
